Word through ActiveX from LV
I was wondering if anyone else had seen this problem:
I wrote a VI on one machine that generates a report in Word 2000 via
ActiveX. Works fine. I then copied this VI to two different machines,
both of which have the same version of Word installed on them, and the
VI is broken. The error messages are similar to those you see when you
open a VI that was written for Word97 on a machine that has Word 2000 or
some other version.
Any ideas would be appreciated.
Dave Thomson
David Thomson 303-499-1973 (voice and fax)
Original Code Consulting dthomson@originalcode.com
www.originalcode.com
National Inst
ruments Alliance Program Member
Research Scientist 303-497-3470 (voice)
NOAA Aeronomy Laboratory 303-497-5373 (fax)
Boulder, Colorado dthomson@al.noaa.gov
Message 1 of 1
(2,531 Views)
