WordView2000 problems
I recently downloaded "WordView 2000" from
<> but have been
unable to get it to work! I have tried everything I know how to do as far
as "refreshing" my ActiveX client and other voodoo, but the VIs in this
product still say "Invoke Node: contains unwired or bad terminal."
Unfortunately, the diagrams are password protected so I can't edit them
myself! 😞
Does anyone else have experience with this product or this type of problem?
It appears to be the solution to my current need to create printable
reports, but I need to try the demo first to make sure!
Thanks!
Justin Goeres
Project Engineer
Indio Systems, Inc.
jgoeres@indiosystems.com
(2,856 Views)
Problem is that you have a different version of MS office and ActiveX refnum
is looking for earlier or older version.
If you can open up front panels for VI's then you can just right click on
the refnum and then assign it to the correct version.
Once you have done it for one refnum then you can just copy and paste over
the rest. I have no idea if password protected VI's will let you alter
their front pannel. Give it a shot.
Reinis Kanders
"Justin Goeres" wrote in message
news:395a3efb@newsgroups.ni.com...
> <> but have been
> myself! 😞
problem?
> Thanks!
> Justin Goeres
> Project Engineer
> Indio Systems, Inc.
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(2,856 Views)
