Work with arrays: 'Delete Item from array'
to get a faster input of data to a driver (DG20220A) I work with the function 'Delete Item from array', but I only need the output 'deleted portion', but not the output 'array w/ subset deleted'. The program only works with a connected output 'array w/ subset deleted'. What can I do to solve this problem.
Thank you very much.
Best regards Bergiel
(2,838 Views)
If you mean the function 'Delete From Array'  in the Array palette,  I don't know why you are having problems.  Having the outputs wired is not required.  Something else must be breaking your VI.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,831 Views)
Hello Bergiel,
maybe you should use "Array subset" instead of taking "Delete item from Array" and using only deleted item. This way LV can run much faster, especially on big arrays.
(2,824 Views)
The way I read this post it sounds like a logic problem, and not a wiring problem. In other words, the way your logic is set up for determining what to delete is backwards.
(2,821 Views)
