Working on a neighbourhood of each element of a 2D array
Hi all,
I have 2D array from an image. I wanna be able to impose a "window" (eg 3x3 matrix) on an element of the array, with that element at the center of that window, so that I can work on this group of data (eg find the maximum value of this window of values). This will be done for every element of the array from left to right and top to bottom. Anyone has a good way of doing that?
Thanks.
(2,657 Views)
If it doesn't need to wrap at the edges, then just "array subset". Am I
missing something?
If it does need to wrap, you just need a bit of extra code to detect a
boundary overlap and retrieve the correct entries from the other side of the
array.
"Kian" wrote in message
news:5065000000080000007B370000-1007855737000@exchange.ni.com...
> Hi all,
> Thanks.
(2,657 Views)
