Working with listboxes
I want to select listbox components by using of mouse and keyboard. As well, I want to automatically select them by using of any mathematic algorithm. Obviously this is easily possible by using of the listbox property "value".
But there are additional properties, which seem to have simillar meanings but also seem to work completely independent of "value": --> "focus line" and "active line" (real property names can slightly differ, I'm working with a german gui)
Is there anybody who can explain, for what these properties are useful? Why does Labview distinguish between three different "active" lines, at the same time!?
(1,584 Views)
Accepted by topic author scr_rhe
Focus line and active line are not the terms used in English...
Perhaps you can post some code? I think you might mean active cell and focus row?
The active cell can be set to change properties, like color or font.
Focus row is the row last selected by the user.
(1,555 Views)
Many thanks,
your assumption about active cell and focus row was quite right.
I played a little with both. Now it also makes sense to distinguish between all of them.
Regards.
(1,514 Views)
