Working with zoom on graphs
Hi guys,
  I have a program that receives data from an outside instrument and I am plotting the data on a waveform graph.  I would like the user to be able to zoom in and out at will while the program is running.  I have tried using the graph pallete but the problem is that when the program updates the graph, all zoom knowledge is lost.  I have tried turing off autoscaling and that seems to work except the data values can change quite significantly, so I need to have auto scaling on.  Any ideas?  I've been stuck for the better part of this afternoon,
PP
(2,855 Views)
You can programmatically control the autoscaling using the Scale Fit property and you can further control the scaling by using the Scale>>Range>>Minimum (or Maximum) property. To create a property node, right click on the control or the terminal and select Create>>Property Node and then find your property.
___________________
Try to take over the world!
(2,851 Views)
