Would you help me to run SimulatedNIcholas?
I try to run the simulatdNIcholas , but there were error. The error is that there are no exist two files.(MSRSProxy.Y2009.M04.dll , Microsoft.Dss.Environment.dll)
I correctly installed the Labview Robotics 2010 and MSRDS R3.
How can solve my problem? Could I get these two files?
(6,721 Views)
I don't think the MSRS example in LabVIEW Robotics 2010 can work with MSRDS R3. R2 should work.
(2,487 Views)
I found this link http://zone.ni.com/devzone/cda/epd/p/id/6443#0requirements  . So, I sovle the above the problem but the othe porblem is happened. The problem is that "there is no NISAST Event.lvclass" . This file is not in the linked zip file. Please help me!
(2,487 Views)
You could find this file under <LV folder>\resource\importtools\Common\Event
(2,487 Views)
