Wrapped VIs nonexecutable
I'm controlling a Patlite USB signal tower using their supplied .dll.  I downloaded the .dll and used to wizard to create wrapped vis and it worked fine in LabVIEW 2021.  I followed the exact same procedure on a different machine using LabVIEW 2024 Q1 and the wrapped vis are nonexecutable.  I get the following message:
The .dll is there and I've verified the required support files are there as well.  Anyone dealt with this type of issue before?  Thanks.
Message 1 of 1
(860 Views)
