Write CAN dbc for .xml with LabVIEW
I need to create a CAN database with about 100 signals. I don't want to manually do this since I will make a ton of mistakes so I'd like to do this programmatically. I suspect this is not possible since I see no hits for this when I search the forums and the web.
(3,454 Views)
Accepted by topic author labviewman
You can absolutely do this programatically.  Go to the Example Finder (Help >> Find Examples)  And check out the CAN Dynamic Database Creation VI.  It will create a cluster, frame, and signal.  It then uses this database to write to it, but you could instead put in the XNet Database Save (which saves it as the XML that XNet likes), or the XNet Database Export (which can export it to a DBC).  This is all found in the Database palette under XNet.
(3,428 Views)
Excellent!  Thanks Hooovahh!!!
(3,349 Views)
