Write JPEG file.vi automatically overwrites
Im using the "Write JPEG file.vi", i wire the path i wish to save the file to from earlier in my program and this cannot be changed. My problem is that if the file already exists, the vi automatically overwrites it without prompting the user. How can i make it possible to prompt the user? Possible some check between the wired path and the directory before running the vi?
Mark
(4,471 Views)
Hi Mark,
you can use the "Check if file of Folder exists.vi" to check if your file already exists.
Which LabVIEW version do you use?
Mike
Message Edited by MikeS81 on 01-07-2009 09:22 AM
(4,468 Views)
Hi Mark,
    Mike given the exact answer while i preparing, just see the attachment
Thanks and regards
Balaji(Certified Associate developer)
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(4,461 Views)
Im using version 8.5. That worked perfectly, thank you very much.
(4,451 Views)
Hai Eastwood,
Is your problem solved? If so please mark (Whichever you think is the best solution for your query). This will help others facing same problem and looking for a solution.
Balaji PK (CLA)
(4,277 Views)
