01-22-2024 02:27 AM
Hello
I use VP9 Codec to store AVI file, but the write speed drops rapidly. What is the reason?
LabVIEW 2020 sp1
Vision 2020 sp1
Thanks.
02-07-2024 03:11 AM
Hi there. Can you attach the VI so I can review the block diagram?
02-20-2024 11:13 PM
Here is the vi, also can find at the path below.
"\National Instruments\LabVIEW 2020\examples\Vision Acquisition\NI-IMAQdx\Stream to Disk\Stream to AVI Files.vi"
04-16-2024 10:06 AM
was also wondering about that. Tested it in LV2021 and 2022 both in 64 bit. The first 24 images are working like a charm, but then the frame time drops as seen in your screenshot.
Anyone got an idea whats going on there?
From the codec comparison example with 10 images, the VP9 seems to be the best codec in regards to file size and write time, but at this state its basically unusable for streaming images to an avi file 😅
