Write Spreadsheet to String Array on another worksheet
thanks,
i will take a look at it.
Krispiekream
Message 11 of 29
(3,178 Views)
Message Edited by krispiekream on 06-03-2010 05:54 PM
Krispiekream
Message 12 of 29
(3,166 Views)
And you're posting that library because ...
Message 13 of 29
(3,148 Views)
i was going to ask a question, so i posted the llb.
but i decided to edit and remove it till i find out my own solution.
you guys are great at answering my questions and are very helpful though.
i havent figured out how to do it yet, but i will soon (hopefully)
Krispiekream
Message 14 of 29
(3,140 Views)
THANK YOU!!!
I did it using ActiveX.
But my code doesnt look pretty
Krispiekream
Message 15 of 29
(3,100 Views)
Why don't you post your ugly code.  I could use a good laugh right now. Smiley Very Happy
Seriously, I would like to see it.  I learn from these things.
- tbob
Inventor of the WORM Global
Message 16 of 29
(3,089 Views)
Alright, Here it goes.
I can successfully create new worksheet with raw data.
but my code is a mess.
BUT I HAVE 1 MAJOR PROBLEM.
everytime I tried to SAVE. It wouldn't save the two worksheets I have.
can someone help me?
Krispiekream
Message 17 of 29
(3,082 Views)
What do I need to put in the ActiveX Save As function for
Microsoft Excel 97- Excel 2003 & 5.0/95 Workbook (*.xls)
Krispiekream
Message 18 of 29
(3,075 Views)
WOW.  You were right about it not being pretty.  You really should break this up into subvi's and a state machine.  Maybe put all of your string variables in a cluster.  This will be a nightmare to troubleshoot and maintain.  Please consider changing it.
As for your saving problem, your code to close and quit Excel is in a separate loop.  This loop will run continuously in parallel with the rest of your code.  I don't think this is what you want.  A state machine would solve that problem.
- tbob
Message 19 of 29
(3,064 Views)
i will try to make it to subvi as soon as I get everything working.
what do i need to put in the text "text.xls" to save it in .xls format?
Krispiekream
Message 20 of 29
(3,056 Views)
