Write String in OPC server
Hello im using Labview 8 an I'm a newbie with that Program
I want to write a String or a date in a OPC Server
Is that possible with Labview, if yes could you tell me how it will work
Regards
Densel
(3,802 Views)
hi there
sure, that's possible!
use the functions from the "DataSocket" palette. Use the "DataSocket Open" function to open a connection once at start of the app, then the "DataSocket Write" function whenever you want to write data and the "DataSocket Close" function at the end of your app to close the connection. right click "Help" on the functions to learn more or search the examples for "DataSocket".
Hint: there's a llb "dataskt.llb" in the vi.lib. the VIs in this llb are not recommended for future use. use the DataSocket functions instead.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,796 Views)
I tried with the Socket connection but i always get the same error
Message "Access mode not supported for operation"
Any suggestions
Message Edited by Densel on 08-18-2006 09:09 AM
(3,791 Views)
your code is correct. it should work. check the opc server security settings of the item you want to write to. opc items can be set to "read only". there should be some kind of configuration application shipped with your opc server.
Best regards
chris
(3,784 Views)
