DIAdem has a built in "time" type. You can easily create a time channel (including information about the date) in DIAdem. Go to the "DIAdem Analysis" window by clicking on the Analysis button on the left. Click on the "Mathematical Functions" button (the first from the top) on the left side of the Analysis window. Select "Generate time channel", the last icon. You can specify a start time, time unit, time step, and end time. If you know this information, and timing is uniform (difference between each element is the same), creating the channel like this in DIAdem is probably the easiest thing to do. If the timing is not uniform, you will have to create the time channel yourself and read it into DIAdem (you could construct it piece by piece in DIAdem also, but that probably would not be as efficient). Hope this information helps. Take care!
Aaron B.
