Write To Measurement Duplicate Timestamps
Is there a simple way to test the rate at which data is received from the COM port? Would be nice to verify that my PIC is sending at the correct rate.
Message 11 of 14
(591 Views)
So you are looking for the baud rate of the COM port recieved data?
Rob S
Message 12 of 14
(566 Views)
Sorry I should have been more clear. I would like to verify that my samples are being read into the serial port at roughly 1 sample every millisecond by being able to write when samples came in and what their values were, without multiple samples having the same time reading as mentioned previously.
Message 13 of 14
(560 Views)
Are you now getting your own timestamp and writing that? Show your new code.
Message 14 of 14
(546 Views)
