Write To Measurement File Only One Line Of Data
I have an express VI setup to acquire a single channel of strain running in a simple while loop.  The output is wired directly to a Write To Measurement Express VI.  However, the resulting measurement file contains only one line of data.
I have tried changing the settings of the VI to no avail.  I feel that I must be missing something basic.  My while loop is setup to take one measurement on demand for each loop.  I am assuming the VI knows to write each loop as a new line of data?
Thanks for any help,
(2,582 Views)
Did you choose "append to file" in the Express VI configuration settings?
You need to upload your VI for further help.  It's impossible to help someone debug a problem without the code to look at.
(2,577 Views)
