Write To Spread Sheet with nested for loop
Hi ,
I have a 3 nested loop running and how could I save all the data to excel file at the end of the day?
Please advice.
Message Edited by Support on 06-12-2008 08:30 AM
Message 1 of 10
(4,670 Views)
It does not really matter how many loops you have stacked, but how you accumulate the data.
Do you simply have a 2D array or something more complicated? How much data?
For long term data accumulation, I would append the new data to a file at regular intervals. It is not save to keep one day's worth of data in memory.
Message 2 of 10
(4,667 Views)
Please find the attached file. How could I save all the data in 1 file at the end of the day. By any means like append or what.
Message 3 of 10
(4,664 Views)
You are not showing how you want the data arranged. There are near infinite ways to arrange the data with your given code.
Message 4 of 10
(4,659 Views)
Any arrangement will do. Please provide me an example that you would arrange your data at your own way.
thanks
Message 5 of 10
(4,652 Views)
Hi cheyne,
I doubt "any arrangement will do"! It's very crucial to put data in correct order... And one should know (or: define) data structures before actual programming!
Anyway: Here's a quick&dirty example putting all data in "random" order...
Message Edited by GerdW on 06-12-2008 10:08 AM
Message 6 of 10
(4,645 Views)
Here's a completely different solution. It really depends on what you want.
Message Edited by altenbach on 06-12-2008 01:23 AM
Message 7 of 10
(4,636 Views)
How if I want to have the data in new row whenever the innest loop finish.
How i could do that? Please advice.
Message 8 of 10
(4,631 Views)
That's what my example does. It will repeat the values for the slower outer loops, but will create a new row for each iteration of the inner loop. Try it!
Message 9 of 10
(4,628 Views)
Thank bro. 🙂
Message 10 of 10
(4,608 Views)
