Write a Spreadsheet file using ULx
Hello:
I would like to improve the output file which I got from my code. I am ok with the spreadsheet which I obtain when I select 1Channel. But when I have multiple channel, the spreadsheet is quite confusing, especially the column for the time.
Can someone give me any tips to improve the output file of my code?
Thanks!
Gianmario
(4,081 Views)
I would just use the Export Waveforms To Spreadsheet File VI.
(4,043 Views)
Thanks for your replay.
I have seen this solution. But when I use this function in a while loop, it does now work. It asks me to replace a file to each iteration.
Do you have a solution for that?
(4,019 Views)
Hi GM,
did you read the LabVIEW help for this function? Did you wire all needed inputs?
(4,015 Views)
Hi GerdW:
You're right. I missed to wire append to file? inputs. Maybe doing that will fix my problem. I am going for it.
Thanks!
(4,008 Views)
