Write a XML file
I want to write a XML file to save many informations ( position , size... of my window for example ) and i'dont know how i can do it ,
i used this method " https://www.ni.com/docs/en-US/bundle/labview/page/parsing-xml-files-in-labview.html " but it not work .
Are you have a other method to do this ?
thank youu for your help .
(5,055 Views)
Accepted by topic author imadouino
Can you show the code which you have developed? and what is the issue you are facing?
Did you try using the Write to XML and Read from XML APIs available in LV?
(5,052 Views)
At first it is just a test.
(5,033 Views)
