Write a fast pulse and read width of the echo pulse
I am using SC-2075 board , NI PCIe-6259 card and LabView 8.5 to test and use a SRF05 Ultrasonic Ranger sensor.
So the sensor need a short 10uS pulse start the ranging and after I need to measure width echo pulse which are between 100uS and 25mS. The sensor mustbe triggered every 50 ms.
I have seen that we can synchronise multi function in  Example->DAQ.mx but I don't understand how I can modfied the counter or the read chain to
write a fast pulse each 50 ms. And after to measure two Edge separation I think that I need too another counter for this task.
Sorry for all this auestions but I just need to practice with LabView and I try to realiser this program for two weeks without resultat...
(3,148 Views)
Two channels.  Channel 1 is a continious pulse train - 10us on and 49.9ms off.  This will send out pulses every 50ms with a width of 10us.  Channel 2 should be a phuls width measure task that is retriggable and the trigger is the falling edge of channel 1 (you can specify the source as the pfi# so this is internally routed.
___| |____________________________________ |-|____________   channel 1 continious pulse train out
         x....|----------------------------------|_                   x.....|-----------|__  Channel 2 'x' is retrigger measure pulse widths
I cant remember offhand which tasks require 2 counters vs 1.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,136 Views)
Yhamks for the answer.
But I don't know how to make this. (yes, I'm really a novice)
Because in Labview example, for the edge mesurement, they use board counter.
And to create the channel 1 , I need to use DAQmx Trigger or DAQmx Write is enough?
i found in a post a program which can be usefull.Can you correct it?
(3,123 Views)
