Write a measurement file in Real Time module
I'm trying to write a measurement file while using the host VI and I'm utilizing the express write measurement file tool.  When I run the VI no file is written. What am I doing wrong?
-wblachfo
(2,865 Views)
Please post your VI so others can see what you are doing and help find the problem. Smiley Wink
(2,854 Views)
wblachfo-
Posting your code (or a screenshot of it) is definately helpful, but here are a few things you might want to check:
-Make sure you are handling the errors (with a simple error handler or automatic error handling)
-Make sure you are sending non-void data into the express VI
-Doulbe check the file name field in the express VI or just use the prompt to choose the file location
We'll know more when we can see your code.
Xaq
(2,846 Views)
