Write a spreadsheet from an array of string
Hi there,
I want to export all the step results of my simulation to excel. However, only the last value of the loop is being exported. Someone can help me with that one?
Thanks in advance.
Message 1 of 19
(4,685 Views)
I guess this will solve your problem.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 2 of 19
(4,678 Views)
Gak,
If u disable indexing then also you aer going to get only single data and that will be the last data of the loop and not the first data...
LV 8.0, 8.6, 2011,2012,2013 WinXP
Message 3 of 19
(4,659 Views)
This solution I've tried already, but it gives me only the last result of my looping.
What I want is to export each result of each iteration.
If you have any other suggestion, please let me know.
Message 4 of 19
(4,658 Views)
Hi Cottbus,
my previous posting will help you i guess.. check the image...
Message 5 of 19
(4,652 Views)
Hi subbzz,
Thanks for your suggestion, could you be so kind and send me a screen where I can find this tool (Write to text file)?
I'm using a german version of Labview 7.1, so I'm afraid I don't have this tool here.
Thanks in advance.
Message 6 of 19
(4,640 Views)
Hi subbzz,
I could build your second solution and it worked well. The problem is that I need to tranpose now my values, because I have to many results.
Any suggestion?
Thanks once again.
Message 7 of 19
(4,631 Views)
it is available in the file I/O
Message 8 of 19
(4,629 Views)
For transpose you can use the transpose array function present in the array pallette
Message 9 of 19
(4,627 Views)
 You cannot use the transpose array function for the for a 1D array.
Cottbus,
if you are getting 1D array why u need to transpose the same?
Message 10 of 19
(4,623 Views)
