Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Write a variable into Case Select
mikey37
Member
08-23-2006
10:43 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Write a new value into Case Select from the fronrt Panel Control,
I have to select by Serial number and do not want to rewrite code to enterr a different serial number to the Case Select
0
Kudos
Message
1
of 3
(2,917 Views)
Reply
Re: Write a variable into Case Select
tbob
Trusted Enthusiast
08-23-2006
11:02 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If I understand you correctly, you want to modify the case selections programatically. You can't do this. What exactly are you wanting to accomplish?
- tbob
Inventor of the
WORM Global
0
Kudos
Message
2
of 3
(2,910 Views)
Reply
Dennis_Knutson
Knight of NI
08-23-2006
11:03 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can't have a variable with the case statement. Do you need to have the entire serial number or just part of it (like a prefix)? Something other than a case statement might work if you would explain exactly what you need to do.
0
Kudos
Message
3
of 3
(2,909 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
