Write all digitall ports (Channels) with decimal value
it is possible to write all digital port with a decimal value for a device with 96 channels in the same time?
I have a USB 6509 device and I want to write each bit whit value 1 in loop (for the first port I write 0,1,2,4,8,16, 32, 64 and 128) with line "Dev3/port0/line0:7", but if I want to write all the ports in the same time how to set the line and the "DAQmx write.vi"?
Thank you.
(2,474 Views)
Accepted by topic author chiritab
You can setup reading and writing in 8-bit ports with the 6509.  So you could just write 128 to "Dev3/port0".  If you want to write to all 12 ports, I recommend making a task that is multiple channels on the 6509 module, each channel in the task being a port.  You can then use the Multiple Channel, Single Sample to write your values.  Your values will need to be in an array of U8.
GCentral
(2,441 Views)
