Write & Read Binary files in a MultiChannel Con't DAQ
Hi there,
I'm using NI-DSA 4472 and the lockin startupkit(DAQmx version) but I need to modify the program so that I can record the data. The data type are DBL.  I tried using 'Write to binary file.vi' and  'Read from binary file.vi'. They are working for my test vi which is a single channel DAQ, but for MultiChannel I guess I need to create a header for the file. I found an example "Cont Acq&Graph Voltage-To File(Binary).vi" and "Graph Acquired Binary Data.vi" but it seems they deal with unscaled data I32.
Any suggestions or right directions you can point me to for writing a header for Multichannel DAQ with DBL data type and convert the binary file to a txt file when the data are read later by another 'Read binary file' vi.
Thanks!
MAE at Rutgers
Chen
(2,329 Views)
You could try using the TDMS write and read VIs instead.  They provide a place to enter the group and channel names.  Also, if you use a waveform data type with the TDMS write, the channel names are already included.  I havent used the TDMS format with DBLs, but it has worked well with waveforms and it is a fast and compact file type.
Hope this helps.
--Robert
(2,316 Views)
Thanks, Robert.
The reason I want to write to binary file is because it's fast. I know nothing about TDMS file, but I'll take a look at it.
Chen
(2,311 Views)
