Write & Read Config VI's
Hey Dan, I did that before It was just my mistake when i attached the files, when I run that little vi it tells me that found the key in the right section but when the value that is coming out of the read key is 10 and not 120 which is what i have in the file.....could you run it if you can and see what you get
Message 11 of 14
(965 Views)
The value that it will pass its 5(default)  if it does not find a key....the 5 and 120 are random numbers, they are not actually the real values....
Message 12 of 14
(964 Views)
You aren't making any sense. The value you have in the file is 5. Not 10 or 120. If you really have fixed the problem with the section name in the VI, everything works. If you change the value in the text file, save it before trying to read it again. Also, the convention for config files is use the .ini extension.
Message 13 of 14
(956 Views)
Dan,
Thanks I got it working finally...Thanks for all your help
Message 14 of 14
(949 Views)
