Write an array of signals with respective timestamps, to be opened with MS Excel.
I have a while loop to collect voltage readings. I would like to write a file to have each voltage signal and each respective time stamp, to be graphed in MS Excel.
Thank you for your time,
Mike
(2,318 Views)
Your VI makes no sense. You have an analog input task but you are doing a write. You are not reading any voltage at all.
If you change it to a read, read back as a waveform to make it simpler.
(2,312 Views)
Markhipov,
Dennis is correct your VI is configured for a Analog Input Task, but then you are using DAQmx Write instead of a Read. Here's a link to an example from our community that is doing something very similar.
https://decibel.ni.com/content/docs/DOC-8669
Danny F
Danny Funk -- Senior Group Manager -- Software R&D -- NI
(2,288 Views)
