Write and Read data to file
I am working on creating an data file and I need it to save all data to an .text file and read from that .text file from the application folders position.
I got 3 numeric input and 3 numeric outputs.
How do I create one file and then read the file and split the data to the 3 numeric outputs.
kls
(5,577 Views)
Use
and
(5,561 Views)
Yes I am looking at that.put the
How do I put the 3 inputs to an 1D data and then split it again when reading.
kls
(5,553 Views)
Hi Kim,
to learn how to build an array and how to index elements from an array you should look up the "Getting Started" section on top of the LabVIEW board!
(5,544 Views)
Accepted by topic author Kimlorentz
Got it working. Tnx for the help.
I made an sub folder for the data that needs to be saved.
kls
(5,518 Views)
