Write data from 1D array of cluster of 2D array to a file
I have 1D array of cluster of 2D array, but now i want to get the data from the whole array so that i can program them using Matlab.  I try to connect the 1D array of cluster of 2D array to the I/O Function called "Write Labview Measurement File" , but it doesn't allow me to do so. Do you have any  method that i can get the data ? Thank you
(2,965 Views)
This is a duplicate post.  See the original response here.
-D
(2,946 Views)
