Write data to Text file - Column by Column
I want to write a table of data(2D) to a text file. I acquire 1D array(6 lakh rows) of data & want to write that in text file as column 0. And next 1D array to the same text file as column 2. Is it possible todo that?
I don't want to accumulate 2D array and write at last since it consumes more memory & Labview Hangs.
Kindly share your ideas.....
Labview 8.2
Raja
Message 1 of 13
(7,799 Views)
Why not write it row by row? To be able to do column by column you would have to reread the file every time you want to append data. It is very inefficient.
And just for knowing: How much is "lakh" for the non-indian folks?
André (CLA, CLED)
Message 2 of 13
(7,795 Views)
I want the text file in Table format (2D Array) . Each column represents 1 particular channel data.
The size of the 1D array is 600000 rows.
Raja
Message 3 of 13
(7,792 Views)
            Insert into array may work.Specify the column index and insert 1st column and later.
Message 4 of 13
(7,791 Views)
I didn't get you. Can you explain with an example.
Actually I want to append the 1D array of large data  to a text file in column wise.
Is it possible to do that?
Raja
Message 5 of 13
(7,782 Views)
If a column is representing a channel the file would look like this:
ch0 ch1 ch2 etc
v0 v0 v0 etc
v1 v1 v1 etc
This is what I meant by "row by row".
Each acquisition step is written to file as one row.
Open file
For each acquisition of all channels
  Set file pointer to end of file
  Write data line
EndFor
Close file
André (CLA, CLED)
Message 6 of 13
(7,781 Views)
Why would you want to do that?
André (CLA, CLED)
Message 7 of 13
(7,780 Views)
1,00,000 (1 lakh)
10,00,000 = 1,000,000 (10 lakhs = 1 million)
comma plays it all
Message 8 of 13
(7,775 Views)
HI,
           I hope this works for you but this vi doesnt hanged my PC or Labview. Please check with it and let me know.
Gita
Message Edited by AutoTEC on 10-17-2008 04:15 AM
Message 9 of 13
(7,748 Views)
Can you post that vi in 8.2 ?
Raja
Message 10 of 13
(7,713 Views)
