Write data to text file on command using trigger
Hi there
I'm kinda new to using Labview, and i seek some advices.
I've got this program, which is used to read from a usb-device (6215). It measures the voltage at an input channel on the usb-device, and processes it, and finally writes the data to a txt file. I want to control when it writes the data (only one instance/ measurement at a time) via a trigger.
The problem is, that the trigger does not work. It always writes to the file i have specified. Can anyone help me getting this right?
Furthermore, if someone have any suggestions how to make the data in the text file more readable (i'dd suggest using colums - but how?) i would greatly appreciate it. Maybe converting to an exel-document could be the answer?
 Thank you in advance, Troels
Ps:
Hope you can see past the danish text
(2,994 Views)
Your true and false cases are identical and the file write is outside of the case statement. The boolean trigger does nothing. Why don't you try putting the file write inside the true case statement and nothing in the false case? You wouls also place the DAQmx Read inside the true case.
If you are not going to use an event structure (but you should), place a Wait (ms) function inside the loop.
(2,989 Views)
