Write digital waveform to NI9401
I've an issue when I try to write a digital waveform to my ni 9401 mounted into a cDAQ-9188XT.
I've connected the output of ni9401 to my oscilloscope but the signal is not in the range specified by "dt" of the waveform. Furthermore the "dt" parameter seems to not modify the behavior of the waveform when I try to change it.
I've attached screenshots and the vi.
Thanks to all
(2,813 Views)
try to have a look to this example.
Hope it helps!
Bye!
Licia
(2,766 Views)
