Write measurement to file every X minutes
Gerd,
I read everything, but still i didnt use case block, so i didn't want to start a new issue 😄
Now is working fine , by the way i am getting an error using measure writting about saying file already open. Weird stuff
Message 11 of 14
(1,527 Views)
Ravens,
The event structure above is just testing. Its a freaking GPIB interface , but not working, weird stuff about time out and number of bytes so... will delete
Message 12 of 14
(1,525 Views)
@GerdW wrote:
And you forgot the case structure - I repeat:
Use the ElapsedTime ExpressVI and a case structure…
(I wonder why people asking for help don't read the answers carefully…)
To put the suggestion into pseudocode:
IF ElapsedTime(X minutes) THEN
  save data to measurement file
ENDIF
The Write to Measurement File probably still works without the case structure.  Only because it looks like th OP wired the Time Elapsed? boolean to what is probably the Enable? input of the Write to File, so the case structure is effectively buried inside of that Express VI.
IvanHe,  is there any chance you get the file error because you DO have the file open somewhere else?  Like looking at it in Excel?
(As Gerd says, it is kind of hard to debug VI's from pictures.  Also, if you get an error than be sure to give us as much detail as possible such as what the error number is.)
Message 13 of 14
(1,523 Views)
Thank's!  you save my day !! i spent 4 hours trying to fix freezing data while recording at every 1 min . 🙂 thank you again !!
Message 14 of 14
(852 Views)
