Write multiple measurements to file
I added the rest of my code and having a issue with the loops.. I want to be able to manually switch the circuit which would require using a while loop instead of a for loop.. Is it possible to exit the case structure with a command because my current code will run Voh non stop.
Message 11 of 16
(2,644 Views)
You can't "exit" a case structure.  All code inside has to execute.
You can exit the while loop.  You have the stop button in there which means the while loop will stop executing once it has read that the Stop button was pressed.
Message 12 of 16
(2,635 Views)
Is there a way to make it run only once? Currently, I'm not able to switch cases.
Message 13 of 16
(2,632 Views)
Don't put in the while loop.
Message 14 of 16
(2,629 Views)
Ok, is it possible to use a for loop and have it wait for my case to change?
Message 15 of 16
(2,625 Views)
I don't understand what you are asking with that question.  How is the case going to change?  Right now it is a control on the front panel.  And it happens to be read one time when your VI starts.
I would recommend you learn more about LabVIEW from here. How to Learn LV
Message 16 of 16
(2,612 Views)
