Write permission for labview.ini
When I select Tools > Options, LabVIEW gives me this error: "You do not have write permission for the LabVIEW configuration file...."
LabVIEW 7.1
OS: Win2000
I am a user in the Administrator Group. The machine is on a large network with a domain. If I log in as "Administrator", there is no error.
(2,893 Views)
> LabVIEW 7.1
> OS: Win2000
> error.
You apparently installed LV in a location, then changed user IDs so that
you no longer have write permission there. To make LV use a different
..ini file, make a shortcut/alias and set the command line to contain
-pref "prefFileName" with any sort of path you like.
Greg McKaskle
(2,893 Views)
Thanks for the answer. Your assumption was correct. Details: In the shortcut Properties, I set the Target to:
"C:\Program Files\National Instruments\LabVIEW 7.1\LabVIEW.exe" "-pref" "c:\UBTS_Dev\labview.ini"
(2,893 Views)
