Write special text to EXCEL using report generation toolkit
I have been searching for a solution to this issue for quite a while but not able to get a good one yet. What I try to do is to write an array of text data to EXCEL with the Report generation toolkit. What makes this difficult is some such array elements are of the pattern resembling to an exponential numerical value, such as "20e00". In this particular case I would like the exact text of "20e00" withing the quotation mark to be written. However, with my simple code as attached, EXCEL sheet gets "2.00E+01" or 20 depending how I format in EXCEL. So my question is, is it possible to have some further configuration or formatting on the LabVIEW side to get output as I expect?
Tao
Message 1 of 10
(4,660 Views)
Use a template:
Format the cells as TEXT in Excel, and save it as template.
When Create Report in LabVIEW, use the template.
George Zou
Message 2 of 10
(4,621 Views)
Try putting an apostrophe in front of values.  That seems to be Excel's way of interpreting anything as text.
aputman
Message 3 of 10
(4,616 Views)
I just tried that trick before I post.
It doesn't work with the easy table.vi
George Zou
Message 4 of 10
(4,606 Views)
Accepted by topic author stevensung
You can also use the Set Cell Format VI with an ampersand @ as the format code.  You have to do this before you add the text, otherwise Excel makes its own decision first and you lose the scientific notation.
aputman
Message 5 of 10
(4,606 Views)
You have to double apostrophe it.
aputman
Message 6 of 10
(4,602 Views)
Double works; @ doesn't.
George Zou
Message 7 of 10
(4,599 Views)
Does for me.
aputman
Message 8 of 10
(4,594 Views)
Interesting. Only one gets written into the cell.
The first one serves as an escape key?
@ works too.
George Zou
Message 9 of 10
(4,579 Views)
Thanks aputman. I tried to insert that subVI that formats the output table as text by setting "@" but put it after setting table data. Swapping order of these two as you suggest actually solve the problem.
Message 10 of 10
(4,575 Views)
