Write to BMP or JPG file
Can anyone tell me if there is a VI available that will write a graph
display to a BMP if JPG file. This is to save having to [print screen] and
edit the picture all the time.
Yours sincerely, Chris McCrory Project Engineer
______________________________________________ SP Technology Limited E-mail:
c.mccrory@sp-tech.com Website: www.sp-tech.com Tel: +44 (0) 1382-880088 Fax:
+44 (0) 1382-880099 The information in this e-mail is confidential and for
use by the addressee(s) only. If you are not the intended recipient or
responsible for delivery of the message to the intended recipient, please
notify us immediately on +44 (0) 1382 880088 and delete the message from
your computer; you may not copy or forward it, or use or disclose its
contents to any other person. As Internet communications are capable of data
corruption, SP Technology Ltd do not accept any responsibility for changes
made to this message after it was sent. For this reason it may be
inappropriate to rely on advice contained in an e-mail without obtaining
written confirmation of it. Please note that SP Technology Ltd does not
accept the liability or responsibility for viruses and it is your
responsibility to scan attachments, if any. Opinions and views expressed in
this e-mail are those of the sender and may not reflect the opinions of SP
Technology Ltd.
(2,827 Views)
"Chris McCrory" wrote:
>Can anyone tell me if there is a VI available that will write a graph>display
snipp
Just use the VI-Property Node - you can choose to print the whole VI (description,
panel, diagramm and so on and delete the unnecessary stuff.
Peter
(2,827 Views)
