Write to Excel to separate column
Hi all,
Could anyone tell me how to some data to a separate column in Excel sheet. I have attached here a picture
for you to understand my code and what I intend to do.
thanks,
keng
(2,702 Views)
If you are going to be doing much programming at all with Excel in LabVIEW, I would highly suggest getting the Microsoft Office Toolset for LabVIEW. It is extremely helpful. The toolset provides higher level VIs which allow you to create reports easily and lower level VIs to allow for more customization of the report. What you are looking for here would be very easy with the toolkit. I've tried it as you have it, but it would take more knowledge of the Office ActiveX interface which would probably be found on Microsoft's website.
J.R. Allen
(2,702 Views)
Hi JRA,
Thanks for looking into my problem.
Well, I could have adjust the template Excel to meet the my codes. However, I know that the toolkit is very userful but it cost money. I would have to consider to about it.
Anyway, thanks for your opinion.
keng
(2,702 Views)
