Write to FPGA Boolean Control from RT...will it switch or latch?
I have a reset button in my FPGA code which I am setting from the RT. After this button has been set, do I need to "pop" it back out when the FPGA reads it? Do the switch/latch function settings make a difference? If I set it to latch, will it handle the return to false, after it is read, for me?
(3,224 Views)
Accepted by topic author GregFreeman
There's no latching. It would be nice if there was, it would make implementing handshaking with booleans a lot easier.
(3,205 Views)
Not the answer I wanted to hear! But thanks.
(3,201 Views)
