Write to File with Time Stamp for LVM
I am relatively new to LabVIEW and thus would really appreciate your assistance/patience. I am trying to do something that seems to be very simple but I have not found a solution that has worked in manuals and online. I want to write to a LVM file in two columns one with a time stamp and one with data. I am using the express VI for Write to File. Is there a simple way to do this?
(3,217 Views)
Turn your tunnel into concatenating mode so it creates a 1-D array instead of a 2-D array.
How long will this VI run?  You don't want to continually build an array at a loop boundary eating up all your memory if it runs a long time.
(3,214 Views)
What's an LVM file?
I find it a lot more useful to save data in a "standard" format like CSV or better yet a tab delimited text file.
Both of these types can then be easily opened in Excel for data analysis.
=== Engineer Ambiguously ===
(3,206 Views)
A LabVIEW Measurement File (LVM) is a text based file. The specifications for the file are here.
Specification for the LabVIEW Measurement File (.lvm)
From <https://www.ni.com/en/support/documentation/supplemental/06/specification-for-the-labview-measuremen...>
All the separate file formats have their strengths, for Excel viewing, the .xlsx file works well too.
Anthony M.
Applications Engineering
(3,142 Views)
