Write to Measurement File: Time has minutes and seconds. Where are the hours?
I have dynamic data acquired by Express VI: DAQ Assistant from a CompactDAQ and wired to Express VI: Write to Measurement File. In the resulting text file in the header the Date is recorded correctly in DD/MM/YYYY format. The Time field should be formatted HH:MM:SS.XXX but all I see is MM:SS.XXX. Is there a setting I should change to see the hours?
Andrew.
(2,505 Views)
Found the answer, sorry. Excel formatting issue. Not LabView after all.
Please delete this thread.
Cheers,
Andrew.
(2,504 Views)
