Write to Serial with VISA
Hello everybody,
I am now searching quite a time to solve my problem, but i couldn't find anything working for me. I try for the first time to set up a Serial communication via the VISA VIs to my arduino uno board. I was following the most simple examples i could find, but nothing worked so far. I attached my minimal example. I figured it should actually work simple as that...
The thing is:
- The serial communication with my arduino works in principle. It does what it should do using the Serial monitor coming along with the Arduino IDE
- Using my vi nothing happens
- The return count is always showing 0. I thought it should show the actual size of the buffer. So my guess is that the vi is just not writing anything to the buffer.
I know that there are tons of other posts about serial communicationvia visa between labview and ardunio, but all i could understand from them is that my way of using the vis should actually work.
Anybody can see my mistake?
(2,957 Views)
Accepted by topic author Wombat85
Ok, nevermind. For sure, right after posting I tried the thing that helped: You can't have the Arduino IDE and LabView open at the same time. Both trying to get access to the same COM-port won't work... As I see it, it was all my problem. Sorry for bothering 🙂
(2,946 Views)
