Write to Spreadsheet adding extra rows in csv file
Hi All,
I am creating a program which measure current over time.  It is working well, but when I write to spreadsheet, there are extra rows between the row of data.
I created a header file, which is passed into the while loop where data is entered into an array and then entered into the spreadsheet.  If I simply display the array, there are no extra rows, but when I open the csv file in excel, there are more rows.  I am pretty new to labview, but everything is running the way I want (it is a simple program) except for this.
Message 1 of 13
(12,233 Views)
Why are you overwritting the entire each time you capture data?  Set the "Append To File" to TRUE and write the header before the loop.  Then you just have to write your single line inside of the loop.
Even better would be to open/create a file, write the header, and then directly write your data to the text file, and close the file after the loop.  This will make your loop run a little faster since the file stays open instead of opening, writing, and closing each time you add more data.
Message 2 of 13
(12,222 Views)
The reason I am saving each time is because I want the data to save if I have to click stop.
I will try your suggestion soon to make the loop run faster, thank you.
However, I still don't understand why it is adding extra lines in the csv file, but at the same time, it isn't if I am simply displaying the array.
Message 3 of 13
(12,218 Views)
Accepted by topic author _natalie_
There is a carriage return or line feed in your string data.  You can get rid of this by adding a "trim whitespace" function between the "visa read" function and the "replace array subset" function.
Message 4 of 13
(12,205 Views)
@_natalie_ wrote:
Hi All,
You should alter your File I/O like crossrulz said to at least append to file instead of saving the entire array of file data each time around. If this ran for a really long time, that array will get bigger and bigger and bigger until you bog down your program. Since you're looping at about 0.2Hz according to your defaul value, opening the file and closing it each time isn't a problem, but you should keep that in mind for future programs or if you want to speed this one up.
Excel is looking for line feeds and carriage return values to know when to go to the next line. It looks like you're reading from a VISA resource. Your instrument might be using a carriage return or line feed as its end-of-data marker, so that could be what's causing your problem if you're including that. Try adding a Trim Whitespace node to that string right after your VISA Read and see if that fixes your problem.
Cheers
Message 5 of 13
(12,198 Views)
Thank you Jordan, works perfecty!
Is it giving a linefeed because it is outputting a string?
Message 6 of 13
(12,191 Views)
Thank you as well James_Morris.  I will try appending the file to make it run faster, still learning!
Message 7 of 13
(12,184 Views)
No.  It is because your instrument is sending the Line Feed.
Message 8 of 13
(12,180 Views)
Thank you, too, crossrulz!
Message 9 of 13
(12,176 Views)
A good rule of thumb when working with VISA or other instruments that are communicating with strings is to add an indicator in there that shows you the output and configure the indicator to be "\" display (right-click menu option). This will show you all of the whitespace characters in "\" format. Line feeds are "\n", return key is "\r", space is "\s". Those whitespace characters have caused me a lot of grief in the past.
Cheers
Message 10 of 13
(12,132 Views)
