Write to a specific line in text file
hi let say text file with five lines
i need to write it in a specific line example line 3.
how to do tht,
thk u
(4,765 Views)
Hi jeyanthi,
here is an example how you can solve it with your data.
Hope it helps.
Mike
Message Edited by MikeS81 on 05-23-2008 08:05 AM
(4,759 Views)
In Mike's example, you cna change the constant 2 to a control which allows ytou to select which line to write to.
2 meaning the third position becasue indexing starts at 0.  😉
(4,731 Views)
I read the question as wanting to insert text into an already existing text file. If that's the case, you need to read in the text file, insert your text, and then write out the new text to the file.
Could be wrong though.
(4,701 Views)
@Mike can you tell me what is the name of that block which is  deciding line number (input "2")
(2,592 Views)
(2,584 Views)
