Write to a .txt file if you build a .exe file from you VI
While trying to end the labview projects that I have running, I encoutered a problem. If I build an .exe file from this simple .vi file it won't write the string to Example.txt while, if you execute the .vi file it will create the .txt file and write the strings to it. Is there something special while building the .exe you have to do to make this work? Thanks!
(2,904 Views)
You have to strip the path twice in an .exe file.
see this tread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=430908#M430908
(2,900 Views)
Thank you very much, I love simple solutions Smiley Happy
(2,895 Views)
