Write to file in CRIO
hi
i am getting 5 temperature signal every few 5 sec from my compactRIO and trying to write them in 5 different columns. however when i use write to measurement file or TDMS to write it, it writes all in one column. how can i write each temperature in a separate column.
(2,409 Views)
Accepted by topic author process_automation_and_control
i found the answer to my question,
basically i needed to rearrange my array before feeding it to TDMS write
if you have the same problem u can use the following link
the link
(2,406 Views)
