Write to file produced a file of concatatenated array data.
During a continuous aquisition (60 channels; 200 Scans/s)I used AI Read.vi to read 100 scans at a time, then the sampled data was processed and written to a file as a 2D array of single precision numbers to a file using Write File+ [SGL].vi. When the data was read back, I found with each call to the writing vi the data had been written as sixty concatenated (100 sample) blocks of data instead of a 100x60 2D array. Has anyone seen this before or have any insight as to why data would be written in this manner?
(2,425 Views)
The data as it comes from the DAQ board is not row * column but the
opposite. To get it right wire the array trough the Transpose Array
function found on the Array palette before wiring it to the
Rolf K
(2,425 Views)
