Write to measure file posts all the data received from the DAQ in one column?
My program has a DAQ that reads six different channels. The channels are separated and sent to a write to measure file. When I open it in excel the data is all in one column. I want the time in a column along with the data from each channel. Total of 7 columns.
(2,792 Views)
Also, I have tried different settings in the write to measure file; such as, the tabular or comma, segement header, file format and in the excell settings. Still no change.
(2,791 Views)
Accepted by topic author Relient
I think the problem is in how you are building your array.  Try this.
(2,787 Views)
Thank you that worked perfectly.
(2,766 Views)
