Write to measurement file Express VI - TDMS file has separate "channels" for each data point
Im trying to write a VI to measure and record thermocouple data from an Advantech T/C DAQ. Using the "DAQNavi" express VI provided by them, connected to the Write to Measurement File express VI, I have managed to read in the data and create a TDMS file. However, when I open the TDMS file, each time step of temperature data is entered as a separate channel, instead of all of the channel data going into one tab. Obviously this is a huge problem as it creates hundreds of tabs after just a few seconds. Any thoughts as to what causes this?
(2,453 Views)
Hi glibby,
How did you configure the Write to Measurement Express VI? Please select "one header only".
If you have your own timestamps to write, please merge your timestamp channel and measurement channels with "Merge Signals" before passing them to the Write to Measurement.
Best Regards,
Mavis
(2,439 Views)
