Write to measurement file, enable/disable action cause time TDMS BUG
Hello, scusme for my bad english,this is my problem:
I enable and disable the write to measurement file function some times during a measurement.
when i close the programm and i want to show the TDMS file with the function TDMS wiever.vi i see in the "specific", example: start at 12:00:00 end at 12:00:20,
and this is right, but in tis time i enable and disable some time the function, in the graph i see only the start time and the total time the functin work but not the correct time when the data i logged...
see picture 3, there is no interruption on the signal...
(2,719 Views)
This is actually expected behavior..
What do you exactly want to do in the end?
Did you try to search the "Example Finder" for an example that fits your needs?
There is lots of good example, which are a tremendous starting point for many problems..
Kind regards
adigator
(2,667 Views)
